Non Converge on Drucker Prager Simulation
Hello there,
I'm studying the displacement on an earth dam caused by the water on one of the sides.
The parameters i used were as follow :
USING SFGRAD
/prep7
K,1,0,0
K,2,122.5,30
K,3,134.5,30
K,4,257,0
L,1,2
L,2,3
L,3,4
L,1,4
FLST,2,4,4
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
AL,P51X
ET,1,PLANE82 !PLANE 182 E 183 NÃO PODEM SER USADO PARA DRUCKER-PRAGER
! DEFINIDO AS CARACTERISTICAS DO MATERIAL QUE FORMA A BARRAGEM
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,1.68e3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,16412.18e3
MPDATA,PRXY,1,,.49
TB,DP,1,,,
TBMODIF,1,1,20e3
TBMODIF,1,2,10.78
TBMODIF,1,3,0
!CRIANDO A MALHA
ESIZE,2,0,
MSHKEY,0
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
!CONTRINGINDO A BASE EM Y E O LIMITE À DIREITA EM X e Y
FLST,2,1,3,ORDE,1
FITEM,2,4
DK,P51X, , , ,0,ALL, , , , , ,
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,UY,
!APLICANDO O GRADIENTE DE PRESSÃO
SFGRAD,PRES,0,Y,0,-9810 ! PRESSAO INICIANDO EM 0,CADA METRO EM Y REDUZ 9810
nsel,s,NODE,,3,129 !SELECIONAR OS NÓS DO CONTATO (NSEL) ALTERAR SE ALTERA MALHA
SF,ALL,PRES,294300 !todo os nós , pressão inicial
/SOLU
!PARÂMETROS DA SOLUÇÃO
NROPT,UNSYM
NLGEOM,ON
ANTYPE,0
NSUB,500,700,400
TIME,1
Using constant pressure along the slope :
I noticed that it does converge if the pressure is not that intense (until around 110kN/m)
But, using a small value will not satisfy my goal.
I hope you guys can help me.
USING SFGRAD
Spoiler:
/prep7
K,1,0,0
K,2,122.5,30
K,3,134.5,30
K,4,257,0
L,1,2
L,2,3
L,3,4
L,1,4
FLST,2,4,4
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
AL,P51X
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PRXY,1,,.49
TB,DP,1,,,
TBMODIF,1,1,20e3
TBMODIF,1,2,10.78
TBMODIF,1,3,0
!CRIANDO A MALHA
ESIZE,2,0,
MSHKEY,0
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
FLST,2,1,3,ORDE,1
FITEM,2,4
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,UY,
/SOLU
NROPT,UNSYM
NLGEOM,ON
ANTYPE,0
NSUB,500,700,400
TIME,1
Spoiler:
/prep7
K,1,0,0
K,2,122.5,30
K,3,134.5,30
K,4,257,0
L,1,2
L,2,3
L,3,4
L,1,4
FLST,2,4,4
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
AL,P51X
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,16.8e3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PRXY,1,,.49
TB,DP,1,,,
TBMODIF,1,1,20e3
TBMODIF,1,2,10.78
TBMODIF,1,3,0
!CRIANDO A MALHA
ESIZE,2,0,
MSHKEY,0
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
FLST,2,1,3,ORDE,1
FITEM,2,4
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,ALL,
!APLICANDO PRESSÃO CONSTANTE de 140kN/m
FLST,2,1,4,ORDE,1
FITEM,2,1
/GO
SFL,P51X,PRES,140e3,
/SOLU
NROPT,UNSYM
NLGEOM,ON
ANTYPE,0
NSUB,500,700,400
time,1
K,1,0,0
K,2,122.5,30
K,3,134.5,30
K,4,257,0
L,1,2
L,2,3
L,3,4
L,1,4
FLST,2,4,4
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
AL,P51X
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PRXY,1,,.49
TB,DP,1,,,
TBMODIF,1,1,20e3
TBMODIF,1,2,10.78
TBMODIF,1,3,0
!CRIANDO A MALHA
ESIZE,2,0,
MSHKEY,0
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
FLST,2,1,3,ORDE,1
FITEM,2,4
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,ALL,
FLST,2,1,4,ORDE,1
FITEM,2,1
/GO
/SOLU
NROPT,UNSYM
NLGEOM,ON
ANTYPE,0
NSUB,500,700,400
time,1
RE: Non Converge on Drucker Prager Simulation
Rick Fischer
Principal Engineer
Argonne National Laboratory
