What is a good substitute for crude oil in the lab?
We are running some experiments on the low temperature properties of oil. The device we are testing will eventually be used with crude oil and I would like to find a reasonable off the shelf substitute we can use for debugging our experimental setup and preliminary testing. Im thinking something along the lines of motor oil. Any suggestions?
RE: What is a good substitute for crude oil in the lab?
There's got to be some oil wells near you somewhere. Go stake one out that has some tanks on the site and wait around until the truck comes and empties the tanks. Or go to the nearest refinery and find the first truck pulling up to unload, then ask the driver if he wouldn't mind if you "borrowed" some of it.
Learn from the mistakes of others. You don't have time to make them all yourself.
you must get smarter than the software you're using.
a refinery should be able to help you out, but since they tend to process crude in very large quantities it may be difficult to find somebody willing to help you out with the small samples you need.
your best bet might be a research facility that is doing work on crude oil processing. they tend to have access to small amounts of various crude oils and may be willing to supply you.
A question that has not been asked (nor has it been answered by you) is how much ersatz Oil do you need?
prognosis: Lead or Lag
