Journal VB, creation of cylinders in the selected points.
Hello everybody. Im quite new with the use of journals. I would like locate differente cylinders taking as input selected points. I know the function select points but I can not associate it with the cylinders. I took the cylinder code just recording the journal,but I suppose it is not the correct way.
Thank you in advance.
Yua.
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UI
Module NXJournal
Sub Main(ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: Insert->Design Feature->Cylinder...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim nullFeatures_Feature As Features.Feature = Nothing
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
Dim cylinderBuilder1 As Features.CylinderBuilder
cylinderBuilder1 = workPart.Features.CreateCylinderBuilder(nullFeatures_Feature)
'cylinderBuilder1.BooleanOption.Type = GeometricUtilities.BooleanOperation.BooleanType.Create
'Dim targetBodies1(0) As Body
'Dim nullBody As Body = Nothing
'targetBodies1(0) = nullBody
'cylinderBuilder1.BooleanOption.SetTargetBodies(targetBodies1)
cylinderBuilder1.Diameter.RightHandSide = "5.7"
cylinderBuilder1.Height.RightHandSide = "0.2"
Dim targetBodies2(0) As Body
'targetBodies2(0) = nullBody
cylinderBuilder1.BooleanOption.SetTargetBodies(targetBodies2)
theSession.SetUndoMarkName(markId1, "Cylinder Dialog")
Dim unit1 As Unit
unit1 = cylinderBuilder1.Height.Units
Dim expression1 As Expression
expression1 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression2 As Expression
expression2 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim pointFeature1 As Features.PointFeature = CType(workPart.Features.FindObject("POINT(3)"), Features.PointFeature)
Dim myPoints As Point
If SelectPoints("Select points", myPoints) = Selection.Response.Cancel Then
Return
End If
Dim point1 As Point = myPoints 'CType(pointFeature1.FindObject("POINT 1"), Point)
Dim nullXform As Xform = Nothing
Dim point2 As Point
point2 = workPart.Points.CreatePoint(point1, nullXform, SmartObject.UpdateOption.WithinModeling)
Dim axis1 As Axis
axis1 = cylinderBuilder1.Axis
axis1.Point = point2
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Cylinder")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Cylinder")
Dim nXObject1 As NXObject
nXObject1 = cylinderBuilder1.Commit()
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "Cylinder")
Dim expression3 As Expression = cylinderBuilder1.Height
Dim expression4 As Expression = cylinderBuilder1.Diameter
cylinderBuilder1.Destroy()
workPart.Expressions.Delete(expression2)
workPart.Expressions.Delete(expression1)
' Menu: Tools->Journal->Stop Recording
End Sub
Function SelectPoints(ByVal prompt As String, ByRef thePoints as Point) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim title As String = "Select points"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim selectionMask_array(0) As Selection.MaskTriple
Dim selObj() As TaggedObject
With selectionMask_array(0)
.Type = NXOpen.UF.UFConstants.UF_point_type
.Subtype = NXOpen.UF.UFConstants.UF_all_subtype
End With
Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _
title, scope, selAction, _
includeFeatures, keepHighlighted, selectionMask_array, _
selObj)
If resp = Selection.Response.Ok Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
End Module
Yua.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Module NXJournal
End If
Dim unit1 As Unit
Return
End If
Dim point2 As Point
Dim axis1 As Axis
End Sub
End With
selObj)
Else
End If
End Function
End Module
RE: Journal VB, creation of cylinders in the selected points.
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Sub Main() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "cylinders on points" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) 'declare array of tagged objects to be used for the selected points Dim myPoints() As TaggedObject 'allow user to select multiple points If SelectPoints("Select points", myPoints) = Selection.Response.Cancel Then 'user pressed cancel, exit journal Return End If 'if the code gets here, points were selected For Each aPoint As Point In myPoints 'create the cylinders, pass in your own diameter and height values CreateCylinderOnPoint(aPoint, 3.14, 6.28) Next lw.Close() End Sub Function SelectPoints(ByVal prompt As String, ByRef selObj() As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select points" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = NXOpen.UF.UFConstants.UF_point_type .Subtype = NXOpen.UF.UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _ title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj) If resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Sub CreateCylinderOnPoint(ByVal thePoint As Point, ByVal theDiameter As Double, ByVal theHeight As Double) 'Create cylinder code, mostly copied and pasted from a recorded journal Dim nullFeatures_Feature As Features.Feature = Nothing Dim cylinderBuilder1 As Features.CylinderBuilder cylinderBuilder1 = workPart.Features.CreateCylinderBuilder(nullFeatures_Feature) cylinderBuilder1.BooleanOption.Type = GeometricUtilities.BooleanOperation.BooleanType.Create cylinderBuilder1.Diameter.RightHandSide = theDiameter.ToString cylinderBuilder1.Height.RightHandSide = theHeight.ToString 'use the absolute Z vector as the direction Dim origin1 As Point3d = New Point3d(0.0, 0.0, 0.0) Dim vector1 As Vector3d = New Vector3d(0.0, 0.0, 1.0) Dim direction1 As Direction direction1 = workPart.Directions.CreateDirection(origin1, vector1, SmartObject.UpdateOption.WithinModeling) Dim axis1 As Axis axis1 = cylinderBuilder1.Axis axis1.Direction = direction1 Dim nullXform As Xform = Nothing Dim nXObject1 As NXObject Dim xform1 As Xform xform1 = workPart.Xforms.CreateExtractXform(thePoint, SmartObject.UpdateOption.WithinModeling, False, nXObject1) Dim point3 As Point = CType(nXObject1, Point) Dim point4 As Point point4 = workPart.Points.CreatePoint(point3, nullXform, SmartObject.UpdateOption.WithinModeling) axis1.Point = point4 Dim nXObject2 As NXObject nXObject2 = cylinderBuilder1.Commit() cylinderBuilder1.Destroy() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination '----Other unload options------- 'Unloads the image immediately after execution within NX 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Modulewww.nxjournaling.com
