Simple Channel Design Software
Hey All,
I'm wondering what everyone uses for channel design these days. I have an Old Old Old Haestads DOS Program that have been using (don't laugh... it works) and now I have to get a new 64 bit computer that will run Civil 3D properly and sadly, I have to see my old FLOW MASTER program go by the wayside. I know companies like North American Green have their own software but I've run into trouble with the regulatory agencies accepting designs from North American Green because the the Sheer Stress values they use for vegetation. I also used a program called Ohio Engineering that was Developed by SCS-NRCS and the regulatory agency wouldn't accept it because the print outs didn't display the manning's coefficient. All I'm looking for is a simple program for channel design without a bunch of bells and whistles that will replace my old program and will run on a 64 bit computer.
Thanks in Advance for your Input.
RE: Simple Channel Design Software
http://www.fhwa.dot.gov/engineering/hydraulics/sof...
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
http://www.prosoftapps.com/flowpro.htm
http://windows.microsoft.com/en-us/windows7/produc...
Emulates Windows XP in a shell on a modern computer.
Terry Stringer
Better Hydraulics & Hydrology Software
http://www.HydrologyStudio.com
I will be keeping the old computer for a while. I still have some big jobs in Acad 2008 that I just don't want to take to the new CAD because in the long run, it will save me time to keep the old workstation. I'll be able to use the Flowmaster Program for a while. Like I said, Flowmaster is an Old DOS program that used to run in something like windows 3.1 so I'm lucky to still use it. I had to do some voodoo just to get it to run on XP. I like to keep it because its just a good little hydrology tool not just for channels but thats mainly what I've used it for. I thought about just setting up a spreadsheet too and it would be easy enough for simple channel design.
Sorry HydrologyStudio but I'm going to ignore your shameless plug.
I have resorted to hand calcs when needed, but that's not very efficient.
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com
I found this link:
http://www.pcworld.com/article/243718/run_dos_prog...
It looks like if you might be able to do it but I don't have the new computer to try it yet and you may stand a better chance if your running a 32 bit system. The Real Question may be... Even if you do get it running, how are you going to print? I had to configure my XP computer to capture a printer port. I have a list of instructions on how to do that if you want. I will say this... we just got a new server in the office and when the IT guys got around to connecting my machine to the new server, they were not too pleased with me assigning a printer port to the DOS Software. Somehow it messed up the way they wanted to connect me to the office printers. They Told me not to do it again.
I'll take a stab at it after my new workstation arrives but if you figure it out before me, let me know.
At a previous company I was assigning the plotters using a batch file with the net use command. The owners were very happy that I got their old DOS survey software plotting on upgraded PC's.
http://bwengr.com
I also agree that a 32 bit system doesn't seem appropriate for upgrades but I thought I'd throw it out there just in case. Sometimes we don't get a vote in what systems we get. I did spend some time on my home computer over the weekend trying to get it to work but then life got in the way. I'll Let you know if I get it working.
