PWHT of SA 387 CL. 11 Plate
Good morning,
We have some structural plate to weld in the back pass of the boiler ( economizer ) that supports the economizer itself. It has broken free and we are going to band-aid it until a more permanent fix can be administered at a later date.
We are going to be welding vertical plates ( SA 387 CL. 11 ) down to the top flange of a plate girder ( of the same material ). Both members are around 1 1/2" / 1 3/4" thickness. I could not find SA 387 in D1.1 to see what material number (P#) it was classified under for PWHT/PreHeat requirements. However, in ASME IX, SA 387 is listed as a pressure vessel plate and is a P#4. All of our welding procedures are qualified to ASME IX but in my mind this is a structural weld.
My question is - Should we weld this with our ASME IX procedure for P4 material and then heat treat it in the same manner as a P4 material ? Or would it not need PWHT'd because it is a structural weld and not a pressure vessel ( boiler proper ) ? Or is there any way we can get out of PWHT all together ( this is what we are hoping to do so the unit can be brought back online quickly )
Thank you for your time
RE: PWHT of SA 387 CL. 11 Plate
Yes it is 'structural' in nature, but since it requires PWHT to be safe to use, neither AISC nor D1.1 will recognize it.
I have never personally qualified a welding procedure but I am reading up about temper bead procedure's and it looks like it is very involved with hardness testing and macroetching. I don't see electrode diameter being an essential variable though ?
