Is there an ENV VAR equivalent for IFOR_CONFIG to give the location of DSLicSrv.txt ?
For LUM we had IFOR_CONFIG=PATH\i4ls.ini
Is there a way to do that for DSLS and DSLicSrv.txt?
RE: Is there an ENV VAR equivalent for IFOR_CONFIG to give the location of DSLicSrv.txt ?
Enrolled offline licenses and the licensing client configuration file (DSLicSrv.txt) are located in:
On Windows XP:
License Client Configuration (*)
C:\Documents and Settings\All Users\Application
Data\DassaultSystemes\Licenses
On Windows Vista, Windows 7 and Windows Server 2008:
C:\ProgramData\DassaultSystemes\Licenses
On UNIX:
/var/DassaultSystemes/Licenses
Note: You can change the default value for the path of the client configuration file by setting
the environment variable DSLS_CONFIG to the full pathname of the file, for example on
Windows:
set DSLS_CONFIG=C:\SpecialProject\DSLicSrv.txt
