Estimated corrosion rate from process sample
Hi All,
can someone tell me, how to estimate corrosion rate from process sampling and operating variables in refinery equipment?
Gas absorber and Amine regenerator in amine unit and reactor vessel in Hydrotreating unit?
Thanks in advance
Thanks in advance
RE: Estimated corrosion rate from process sample
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
There is a lot of reference to this on the web.
Modified Couper-Gorman curves will give you a relation between H2S content, temperature and expected corrosion rate for specific materials.
Daniel Breyer
Inspection Engineer
http://lnkd.in/dFcQA-w
