Bearing Capacity of Layered Soils
I am interested in design methods of bearing capacity of a spread footing on a weak soil underlain by stronger soil. Lets assume a firm clay on dense sand. Assuming that removal of the firm clay is not an option. Thank you for your feedback in advance.
RE: Bearing Capacity of Layered Soils
BigH, may it be understood from your comments that there are not predefined design methods for this case. And do you mean a slope stability with a slope angle of zero under a sustained surcharge of equal to the foundation load?
If the distance to the hard layer will not permit the full failure surface to develop, then to use traditional analysis is not correct.
Can also look up Section 4.8 of Fang's Foundation Engineering Handbook, 2nd edition. This gives some insight to the problem although they do not reference one of the original papers (by Button, 1957) on the issue. Hope this gives you some insight into the problem. But a thin layer, as I suggested might be better considered to be squeezing.
