NX9.0.2.5 Limits & Fits Tolerance
I can only assume I've caused the issue ...
If I launch 9.0.2.5 from ugraf.exe, I have this tolerance type as an option.
If I launch 9.0.2.5, making use of my customer defaults, then the option is not available ... refer to the attached image. Neither is it available if I go to the Settings dialog.
Now, for any of my files that were create in 9.0.1.3, opening them in 9.0.2.5, then the tolerance type is available.
NX 6.0.5.3, NX 9.0.2.5
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: NX9.0.2.5 Limits & Fits Tolerance
NX 10 (Testing)
You can't use this tolerance type when dual dimensions are used.
NX 10 (Testing)
