Units/precision out to lunch
Can only one tell me why when I draw a rectangle and type in the dimensions (eg 24x1) the result will be something like 23.897x1.116 ?
I set units to max precision just to check but ..... Program is useless with such lousy tolerances :(
RE: Units/precision out to lunch
I think it happens in Draftsight, too.
Turn off all your running osnaps (or whatever DS calls them), and just add the ones you need as you need them.
Mike Halloran
Pembroke Pines, FL, USA
