500 kV GIS type tested @ 60 Hz
500 kV GIS has been type tested on 60 Hz, would it be ok on 50 Hz operation or I need to recommend retesting?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 500 kV GIS type tested @ 60 Hz
If the manufacturer doesn't want to play ball then take them off the bid list. Most TSO's will be fairly prescriptive about what they will connect to their system, so even if you don't reject it I expect that the TSO might well do so.
Marmite
The only type test that it is not tended refers to maneuvers with capacitive loads.
