Boiler tube in air path
Hi
Due to an erection mistake, I have some tubes coming in boiler secondary air gas path.
What will be the effect, if I dont want to modify it?
Hardly 4 tubes of boiler wall,(approx 50mm length is exposed)
Air velocity is around 60m/s and at 250 deg c
Tube is cooled by water-steam mixture as well
Can I leave it as it is?
If I plan to shield it using 3mm SS sheet, what are the effects?
RE: Boiler tube in air path
Doug
