NDT for socket welds
Previously had socket weld(fillet)crack, analysis revealed the failure was fatigue due to harmonics. Changes are being made to correct the problem at other welds. Would like to know other than dye/pen what is another ndt method to inspect fillet socket welds to check for cracks??
RE: NDT for socket welds
N = Non-
D = Destructive
E = Examination
Examination by definition is "Non-Destructive"
If you submit your weld sample to a lab for "Testing" they will destroy it in a "Test" machine therefore it is NOT non-destructive.
Now, what other NDE options do you have for Socket Weld joints?
VT - Visual - Good for all weld types, but not perfect
MT - Magnetic Particle - Not good for Socket-Weld joints
PT - Dye Penetrate - Good for surface examination
RT - Radiological (X-Ray) - Good for Butt-Welds, Not good for Socket Weld joints
As you have already found out there are few options.
In view of your problem with Vibration I recommend you take out all the Socket-Weld piping and replace it with Butt-Weld piping.
prognosis: Lead or Lag
NDT, NDI, NDT, the only difference is the length of the stick stuck up the person's .....
Best regards - Al
Please explain where your interpretation of "correct terminology" comes from ?
NDT is Non Destructive Testing and has been since Jesus was playing fullback for Jerusalem !!!
Do a search of various codes - AWS references NDT only.
ASME references both.
ASNT stands for American Society for Non Destructive Testing - have you seen ASNE referenced anywhere ?
In answer to shonuffs question - if it is C/S then MT is your best option for surface defects.
On a previous project the Quality Manager misinterpreted the requirements of B31.3 regarding the 1/16" gap before welding and wanted to RT the sockets after welding to confirm the 1/16" gap after welding.
Showed a lot of defects in the fillet welds and cost the project huge amounts of unneccessary time and money but if you want to be 100% sure you have no cracks - RT and MT on your socket welds.
DD
'Tis expensive, but consider replacing them with butt-weld joints wherever vibration is high or medium.
Nuke industry has been having SW cracking caused by harmonics. Their solution, developed thru EPRI, is a 2:1 weld. If the fitting requires a 1/4" socketweld, the weld leg on the pipe is to be at least 1/2". Seems to have cured the cracking issue.
Welds that are high strength with low ductility tend to crack when the welder forget to leave a gap between the end of the pipe that is inserted into the socket fitting and the shoulder of the fitting. As mentioned, the codes require a minimum of a 1/16 inch at the time the pipe and socket are fitted together. When these same joints are radiographed, it is common to see the gap is less than 1/16 inch. Again, the reduction of the 1/16 inch dimension is the result of the weld contracting upon cooling and drawing the pipe further into the socket. The larger the fillet weld, i.e., the more weld passes deposited, the smaller the gap becomes.
The suggestion that the weld against the pipe be made larger is something practiced by the U.S. Navy for many years. The nominal fillet size for Navy work is T by 1.75T where T is the wall thickness of the pipe. The long fillet leg is placed against the pipe. It has been shown to increase the life expectancy when fatigue is a consideration.
A good friend did his Master's Thesis in this very subject.
Best regards - Al
Will not work well at all.
There is no problem with the source being a distance away from what is being radiographed but the film must be in contact.
If the film is not in contact the images portrayed on the film are distorted making interpretation to a code impossible.
DD
RT effectiviness is dependant upon (among others):
+ type/thickness of insulation
+ source (x-ray/gamma)
+ source to object/film distance
+ exposure geometry
+ film type
+ joint geometry
+ type/size of imperfection/discontinuity you are looking to find
+ Operator training/experience
+ material thickness
+ etc
Isn't the most important aspect in this example - object to film distance if you are looking for a shot that is actually going to tell you something ?
Cheers,
DD
Yea, the intent was to illustrate RT effectiveness is dependant on a plethora of factors. In this case, RT would be less than ideal for the application.
