Selection of Sealing plan for Pumps
I am searching for some guidelines on selection of right seal flush plans for a given service of the pump.
Any inputs/help are appreciated.
RE: Selection of Sealing plan for Pumps
AOAlexander,
what type of pump - ANSI or API?
API-682 (that's American Petroleum Institute) and api-610 are good starting points.  additionally, contact the pump mfg for recommendations.
the ANSI pump standard B73.2(? - slightly forgetful and do not have reference materail with me) is another standard.
the seal plan depends upon pumpage, pressures, temperatures, etc.  depending on seal plan, a compatible barrier fluid is recommended.
-pmover
If you could give me operating parametere, I can suggest you the seal and system also
Regards.
ACP
India
