hole callout
hole callout
hole callout
Ok, you guys are going to get sick of me--LOL
I have 2 hole features in my insert
I pick on the new hole callout dimension but It doesn't select anything on the screen when I click on the features in the view
Am I not understanding the use of this
I attached a screenshot
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Nvidia
RE: hole callout
Check your Drawing view and see if it's Lightweight. If so, change it to Exact and see if that helps. If it does, then please call GTAC and open an IR/PR asking that this be fixed.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: hole callout
I wonder if this might be why its not working
I used a datum plane above the part to put the holes in and then intersected the insert with my main shape body to get my desired shape on the top face, which is a contoured shape.
I wonder if that changed the hole features
NX 9.0.2.5 / PDW
Nvidia
RE: hole callout
Yes, that will effect it as well as the function is looking for true arcs.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
