Trane Trace 700 run-hours for specific equipment
thread403-142869: Trane TRACE 700
Does anybody know how to get Trane Trace 700 to show calculated run-hours for specific pieces of equipment? For example, I am trying to see how many run-hours are being calculated for room exhaust fans for three different alternatives.
RE: Trane Trace 700 run-hours for specific equipment
Not off hand, but if you are registered user email cdshelp@trane.com They are quick with responses.
If it was a constant volume fan you maybe able to back it out of the analysis tab/energy consumption/equipment.... sort of a back door way. You would think Trane would have a report for it.... I would email the help line.
Keep in mind room exhaust rates may get goofy on you if you are not assigning enough air to be brought into the exhausted room. Trace won't let a space go negative or positive.
