Can someone please identify this type of switch symbol for me?
RE: Can someone please identify this type of switch symbol for me?
It's an old British standard way of showing the switch.
Taking the top left contact set connecting to wire G14 as an example, the upper contact is made when the switch is in the 'surface' position and the lower contact is made when the switch is in the 'nuclear' position. The vertical lines denote the switch positions, so there is one vertical line for each switch position: a six-position switch would have six vertical lines, etc. The black squares denote the position(s) in which the contact is made.
The most well-deserved Little Pink Star ever!
I have been around for many years. And I have worked with equipment older than me, in the UK, but never seen that before. Impressive!
Gunnar Englund
www.gke.org
I have seen similar conventions. But, Scotty beat me to it and explained it better than I could.
Bill
"Why not the best?"
Jimmy Carter
