Rollover Highlight in NX9
I have had to shut off my rollover highlighting
I also noticed this on one of the viewer systems as well
When you rollover an object and it starts to highlight, everything locks up for about 20 to 30 seconds, then it highlights and you can move your mouse again until the next block starts to highlight, then it locks up again, and again, etc
Is there something wrong with the OOTB setup?
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Nvidia
RE: Rollover Highlight in NX9
If its a complex part or assembly, it's worth making sure you've got hidden edge highlight and selection switched OFF.
www.jcb.com
NX 8.5 with TC 8.3
But I've been working on this file for months, and it just started happening yesterday---after NX9 install
NX 9.0.2.5 / PDW
Nvidia
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 9.0.2.5 / PDW
Nvidia
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
"Quadro K5000 331.82 Your PC currently has the latest driver installed for your GPU. No driver update is necessary at this time."
NX 9.0.2.5 / PDW
Nvidia
Here is what they have listed:
1. Dell Precision T workstation Win7 OS NVIDIA Quadro OEM supported with driver version 331.65
2. Dell Precision T workstation Win8/8.1 OS NVIDIA Quadro OEM supported with driver version 331.65 with a note for Win8/8.1*
3. Dell Precision T workstation LINUX OS NVIDIA Quadro STD supported with driver version 319.32
*NOTE: Windows 8 support policy varies with vendor. Many systems, while they may run Windows 8, are not supported by the OEM due to a lack of testing or drivers. Check with your vendor before deploying Windows 8 to ensure your systems are supported.
Some newer systems, such as the Z1G2 only support Windows 8.1
I personally would uninstall the existing graphics driver and go with whatever matches your hardware configuration. I had issues in the past with using a non-certified driver (it just happened to be the exact same issue you're having but with NX7.5) and rolling the driver back to what was certified fixed my problem. Not saying it's the cure, but for no longer than it takes, I'd give that a shot if you cannot find a visualization preference or performance setting somewhere that is different than what you had set for NX8.5 - assuming, of course that you can recall or had record of what those settings were for NX8.5.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
NX 9.0.2.5 / PDW
Nvidia
NX 9.0.2.5 / PDW
Win 7 Pro x64
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 9.0.2.5 / PDW
Win 7 Pro x64
Has "Preferences", visualization performance, General (tab), Evaluate graphics performance" been executed in NX9 by the current user?
Even if the graphics card and driver are unchanged from NX 8.5 the adjustments that the optimize can provide are not transferred from NX 8.5 to NX 9 (assuming the optimization was performed for NX 8.5). The utility needs to be rerun anytime the Card or driver or NX major version is changed.
Regards, Joe
I have been on the phone with Siemens and we may have narrowed this down to an error in the code
If we exit out of ANT, the behavior stops, as soon as you click the tab to turn ANT back on, it starts again
I will keep you posted.
NX 9.0.2.5 / PDW
Win 7 Pro x64
NX 9.0.2.5 / PDW
Win 7 Pro x64
In lots of cases, this has helped me. Especially in cases, where yesterday NX was working OK, but today I have problems.
The funniest problem, solved with this option was several years ago in solid edge. When I opened SE, all the icons were replaced with smileys.
NX 9.0.2.5 / PDW
Win 7 Pro x64
PR 7166968
Just for your information if you need to follow this one
Thanks for everyone's input on this
NX 9.0.2.5 / PDW
Win 7 Pro x64
