Foundation for Cylindrical Grinder
We are currently working on the foundation design for cylindrical grinders that are in an industrial type building, total weight of unit and work piece would be approx 130kip. The owner/client is specifying an 8' depth of footing for a 6'x70' footprint. This would match an existing unit they already have in there facility. Through discussion in our office, we believe the only reason a footing of this depth would be required is for damping of dynamic forces. Looking at how these machines run, it seems there would not be that much vibration/dynamic forces to require this.
The machines they plan on putting in are used equipment, and no manufacturer information with regards to the foundation requirements can be obtained. Wondering if anyone else has designed for cylindrical grinder foundations and if this thickness of slab seems reasonable, we feel this is overkill for the foundations.
RE: Foundation for Cylindrical Grinder
I have not designed one that big, but i will not say it is overdesigned.
Look at it this way, if you don't provide the 3 times the equipement weight in the foundation and there's a vibration issue, they'll find some crusty old engineer to regurgitate that rule of thumb. Concrete foundations are cheap. I might reproportion the depth, but I would end up with close to the same quantity.
Jed may be onto something! Damn those old crusty engineers and their rules!
http://www.slideruleera.net/MachineryFoundations.p...
www.SlideRuleEra.net
www.VacuumTubeEra.net
I was helping at a high school band competition a few years back. The machine shop across the street from the high school had to stop work that day because the base drums and drum lines in the high school warm-up practice area (the parking lot near the school) were creating ground vibrations that marred the finish on the parts they were trying to grind.
