Using dynamic RAM
Using dynamic RAM
Using dynamic RAM
All my microcontroller projects so far use static RAM for external memory. Now i want to try dynamic RAM in one project.
I have, maybe silly, question. Is it enough for reliable DRAM refresh to simply read data from every
row within specified refresh interval? If so then i can simply use timer interrupts to refresh memory. Is this ok?
Also, why some dynamic(?) RAMs are called pseudo-static?
Raivo
RE: Using dynamic RAM
Hi, yes that works fine.
While your processor could do the refresh, it seems to be a bit of a waste of processor throughput.
Psuedo-static DRAM have built-in refresh controllers, which freshes the memory in the background.
TTFN
