CATIA V5 EXPORT MACRO
Hi guys
I'm newbie in CATIA Automation but I try to create some script/ macro to allows me to Export files from Active Window. I found some script for Export PDF/ DXF but this is not working as desired. Macro should let user choose directory where files should be exported (from Browse For Folder dialog box) and export the PDF/ DXF of active drawing in CATIA.
I have no Idea how to handel with this but I'm trying to "bound" few macros that I found on Google:
Sub CATMain()
Dim Doc As Document
Set Doc = CATIA.ActiveDocument
' Test the document's type, if it is not a drawing document the macro stops
If TypeName(Doc) = "DrawingDocument" Then
Dim DocDocument As DrawingDocument
Set DocDocument = Doc
Else
MsgBox "This macro can be run with a drawing document only."
Exit Sub
End If
Const WINDOW_HANDLE = 0
Const NO_OPTIONS = &H1
Dim objShellApp
Dim objFolder
Dim objFldrItem
Dim objPath
Set objShellApp = CreateObject("Shell.Application")
Set objFolder = objShellApp.BrowseForFolder(WINDOW_HANDLE, strTitle, NO_OPTIONS)
'~ If IsNoData(objFolder) Then
'~ WScript.Echo "You choose to cancel. This will stop this script."
'~ Wscript.Quit
'~ Else
'~ Set objFldrItem = objFolder.Self
'~ objPath = objFldrItem.Path
BrowseForFolderDialogBox = objPath
Set objShellApp = Nothing
Set objFolder = Nothing
Set objFldrItem = Nothing
'~ End If
Dim Doc As Document
Doc.ExportData objPath & "\PDF\" & objFile.FileName & ".pdf", "pdf"
Doc.ExportData objPath & "\DXF\" & objFile.FileName & ".dxf", "dxf"
Set specsAndGeomWindow = CATIA.ActiveWindow
specsAndGeomWindow.Close
End Sub
Could someone help me on this?
Sub CATMain()
Dim Doc As Document
Else
Exit Sub
End If
Dim objShellApp
Dim objFolder
Dim objFldrItem
Dim objPath
'~ Wscript.Quit
'~ Else
'~ End If
Dim Doc As Document
End Sub
RE: CATIA V5 EXPORT MACRO
First observation is that after line BrowseForFolderDialogBox = objPath you should put a Msgbox just to check if you really got the path...then search with Google how to do it ( see this for example).
Looking there, I found that
CODE --> CATScript
Sub CATMain() Const WINDOW_HANDLE = 0 Const NO_OPTIONS = 0 Set objShell = CreateObject("Shell.Application") Set objFolder = objShell.BrowseForFolder _ (WINDOW_HANDLE, "Select a folder:", NO_OPTIONS, "C:\Scripts") Set objFolderItem = objFolder.Self objPath = objFolderItem.Path MsgBox objPath End Subis working fine to get the path where I want to save the file.
Can you continue and post the final code?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Here's an updated code:
CODE --> CATScript
Sub CATMain() 'Retrive the active document Dim Doc As Document Set Doc = CATIA.ActiveDocument 'Test the document's type, if it is not a drawing document the macro stops If TypeName(Doc) = "DrawingDocument" Then Dim DocDocument As DrawingDocument Set DocDocument = Doc Else MsgBox "This macro can be run with a drawing document only." Exit Sub End If Const WINDOW_HANDLE = 0 Const NO_OPTIONS = 0 Set objShell = CreateObject("Shell.Application") Set objFolder = objShell.BrowseForFolder _ (WINDOW_HANDLE, "Select a folder:", NO_OPTIONS, "C:\Scripts") Set objFolderItem = objFolder.Self objPath = objFolderItem.Path MsgBox objPath Set objFolderItem = CreateObject("Scripting.FileSystemObject") Dim ShortPartNo, strFolderPath ShortPartNo = Left(Doc.Name, 8) MsgBox ShortPartNo strFolderPath = objPath &"\"& ShortPartNo & "\" MsgBox strFolderPath If Not objFolderItem.FolderExists(strFolderPath) Then objFolderItem.CreateFolder(strFolderPath) End If Doc.ExportData strFolderPath & ShortPartNo& ".pdf", "pdf" End SubIn script I had to rename current part name cause I have a problem with Drawing file name. It looks like it's getting something like: Part Number+ some characters (probably from UUID).
But I need some help.
How can I force CATIA to overwrite already exported PDF file? Next question is how to bound script with other to make it more automatic? When I save drawing I would like to start my script automaticly. And other thing is how to force CATIA to remember first selected path i.e. at the beginning I choose a directory where to save exported files, but next time it should already remember this direction.
Could someone check the code?
Are you working under a PDM system (like Enovia VPM for example) or with system files (CATIA files saved directly on HDD)?
You cannot use CATIA save command (from drop down menu) and then automatically run macro but you can save CATIA file within macro.
The path where to save is remembered during the execution of the macro.
Are you using this macro in a batch process or just once (for a single file opened in CATIA) and then again later?
You can overwrite any file with macro if is not already opened and if you have write access.
What is exactly the problem with the drawing name (search Google about UUID)?
Fernando
I'm working with CATIA V5 Team Center Integration. So far we don't have any plugin for CATIA Integration in Team Center to export and save PDF and DXF automaticly. That's why I decided to create scripts that's at least export PDF and DXF per "on click" and store on HDD, and later we can easily by drag and drop put them into TC.
Currently script is"asking" me each time I start it where to export the files. It would be perfect if for each session user could choose where to export the files, and decide whether CATIA will remember the selection or user will be able to select new directory every single time.
Currently we are storing 3 types of files: master drawing (either it's in CATIA or NX), PDF and DXF. Export, when it goes about NX, it's made automaticly when saving master drawing, but for CATIA there's no such option in TC. That's why we need to make it manually. So I'm trying to make it at least "half-automated" process for now.
I put already
CODE --> CATScript
Parts and Products files have no problem but when it goes about CATDrawings file name have some problems. Please refer to attached picture.
[URL=https://imagizer.imageshack.us/v2/532x389q90/829/z...]
[URL=https://imagizer.imageshack.us/v2/418x121q90/840/2...]
You can't avoid about asking the path running macro each time, eventually you have to input a fix path inside the macro, without option to browse. You can move files after using another method (a program manager, vbscript...).
For the drawing name you can try to get the name of the first link (meaning the part from where the drawing was created). This is easy working with system files, you can get the name of the part/product and also the path but I don't know how is working with TC.
Fernando
