Grounding for vessel
Hi anyone,
I have some question abot grounding for pressure vessel, I found that many vessel in my facility don't have grounding cable installed and in-service over 20 years without any issued.
What is the true reason to install Grounding for pressure vessel and should we have to install grounding? please share.
Thanks for any help.
RE: Grounding for vessel
Frequently, there are multiple grounding paths for power in a plant, ..... rarely will a piping system or vessel serve as the true ground for a system.... but it can happen.
Does it cost extra, yes...... are the consequences of ungrounded equipment severe....yes..
What does this mean ?
"I found that many vessel in my facility don't have grounding cable installed and in-service over 20 years without any issued."
MJCronin
Sr. Process Engineer
*assumes that the paint is conductive - i.e. inorganic zinc without topcoat, or that the faying surface(s) was unpainted. Not very likely.
Thanks to all, i got an idea that i missed.
