View Contents are missing
Am running with NX-9, I've created a part and drawing for the same in a single prt file. Once i placed the view in drafting mode, i went back to modelling and then hided Datum and sketches with Ctl+W.
when am returning to drafting the view contents are missing. but i could get the grip of view border. but when i try to create an another sheet, its working fine(views are created).
attaching the file for your reference and please help me to recover the sheet.
Manikanda
Manikanda
RE: View Contents are missing
What I have done to restore your drawing views is the following:
1. click the menu/edit/show and hide
2. select Show All and you will display everything that is hidden
3. or click Show instead of Show All and select, what you want to show and what should remain hidden.
