SCR unwanted spurious firing.
3
Hi ppl, need advice to find out, what is causing this unwanted SCR firing.mad
Look:
Link
There u can see the signal at my BT152 SCR gate, that sometimes shows spurious firing,that
looks like a bridge, between two firing points.
If some one can help to discover the culprit, i may upload my circuit diagram.
Thanks a lot.
RE: SCR unwanted spurious firing.
Sorry, heres the right link:ponder
Link
Since it occurs consistently on turn-off you are probably having dVdT turn on due to the type load you're controlling.
Keith Cress
Try a snubber across the SCR.
BTW, MJE1300, was replaced by a bc548 like transistor, that has more Hfe.
Eureka ppl!thumbsup2
As ITSMOKED and BRIANE22 already pointed, voltage rising rate across SCR anode-cathode,
was re-firing my SCR.
Snubber was there, but no really working...
20 ohms resitor (1 watt,sorry), in series with .1uf capacitor, was indeed open because
of heat.
Will keep testing the circuit to be sure thats is OK now, and
Thanks for the feedback! Glad you got it chugging along again.
1W seems too low a rating for that. You might consider bumping it up to 3 or 5W. What happens is the 1W can run within its rating but still be so *(&#*$ hot as to oxidize and kill the solder joints holding it to the board.
Keith Cress
Working OK with 5 watts snubber resistor.
No spurious at all!
Thanks again to eng-tips ppl for your help winkr!
That was fun!
Yuck. In some cases dVdT breakdowns can damage the triac and the damage can grow quickly to outright failure.
Keith Cress
That is not reassuring at all.
Now i am a bit concerned about SCR and Triac erratic temper.
An spurious low angle firing, may cause the load to receive a lot of current.
Guess will try to control my motor, with a PWM signal driving an IRF840 at 310Vcc! sadeyes.
Sorry, dv/dt is 0.25 volts X nanoseconds.
So you've ditched the TRIAC and have switched to a FET? How's that working out?
Keith Cress
Yes, the thyristor approach was left aside by now, until I find a reliable
way to detect zero cross, and be sure that unwanted firing is 100% unlikely.
May be, I will try something with a PIC to avoid fake zero cross detections.
i like SCR because of its incredible current withstand capability.
Triac turn-off failure picture, was not from this motor control project, but from a coffee
expresso machine that I am trying to fix.
So far, pwm with irf is ok.Vcc was not raised to 310vdc, but just 160volts
because Mosfet in not mounted on the heatsink yet.
I keep in touch, Thanx.
Heres a picture of the Drain-Source oscillogram, at 280vdc,
tested during a couple of seconds to avoid mosfet overheating.
Motor is no loaded, but running free.
Would like to know, if rise and fall time are ok, or must be improved.
IRF is working without snubber by now.
I'm not sure why you're wasting time on the 'other' method if you want a functional TRIAC method. There are a hundred million products out there using TRIACs successfully. There are scads of schematics and almost every TRIAC maker has extensive application notes on using their products. Find one and use it.
Virtually all of them require properly sized snubbers.
Keith Cress
Thats right, I may even get a working dimmer for pennies,
but the fact is that i want learn something in the way about switching mosfets,
scrs and the like.
You are very kind to help me, thanx a lot!wavey.
I'm not sure what *.ms12 files are but if you want suggestions on your circuit then try posting a file type people can open.
That constant ringing on the positive part of the your FET waveforms would be rather concerning to me.
