Multiple Cooling Towers equalizer piping
What is the correct way to size an equalizer pipe for 5 cooling towers working in parallel?
I am not able to find this anywhere.
RE: Multiple Cooling Towers equalizer piping
Effectively you will be trying to equalize the pressure in each of the branches. If you have a fixed flow you can introduce orifices to reduce flow in the higher flow branches. If it is more variable you may want to explore using a flow control valve and a flow meter on each branch.
