How to add error handling to partSaveStatus1 = workPart.SaveAs("C:\some.prt")
Hi
I want to add a save as to the end of an NX OPEN vb.net .dll
How to I add error handling to this journal? Also how would I add a user interactive save as if I get an error? I want to have a defult value of "file1" in the user interactive SaveAs.
I am using NX6 in native.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: File->Save As...
Dim partSaveStatus1 As PartSaveStatus
Dim file1 as string = "C:\some.prt"
partSaveStatus1 = workPart.SaveAs(file1)
partSaveStatus1.Dispose()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
End Sub
End Module
RE: How to add error handling to partSaveStatus1 = workPart.SaveAs("C:\some.prt")
you could use:
CODE -->
CODE -->
Try partSaveStatus1 = workPart.SaveAs(file1) Catch exc As NXException 'add error catchement here, you can use exc.message to get the reason for faliure End TryIf you are feeling brave and don't want to (or can't) compile you can add a second module to your code and invoke a form in your journal.
This is a cut down version of a very old journal I made when I was learning how to write nxopen scripts (forgive the 'goto' statements, I'm sure with a little thought you can replace these with some until statements)
CODE -->
Option Strict Off Imports System Imports NXOpen Imports System.Windows.Forms Module NXJournal Public inputdesc As String Public input As String Public form_Desc As String Public button_result As Integer = -1 Public msg As String 'Main Message string decleration to share with form and main module Sub Main() ' ---------------------------------------------- ' User input of Description ' ---------------------------------------------- Dim desc As String desc_input: Dim Input_Box As Form1 inputdesc = "Label Text" form_Desc = "Form Text" Input_Box = New Form1 Input_Box.ShowDialog() If button_result = 0 Then Input_Box.Dispose() If input = "" Then MsgBox("User Must Enter a Description") 'msgbox("User Must Enter a Description") GoTo desc_input End If ElseIf button_result = 2 Then Input_Box.Dispose() 'call dispose_new(filename,saveDialog.FileName) GoTo end_sub ElseIf button_result = -1 Then Input_Box.Dispose() GoTo end_sub End If End If end_sub: End Sub End Module Public Structure DimensionData '''''''''''' ' Fields used in the form UI and the IShapeCreator '''''''''''' ' name for the dimension Dim name As String '''''''''''' ' Fields used only in the form UI '''''''''''' End Structure Module Input_Box ' Form that asks the user to select a shape Public Class Form1 Inherits System.Windows.Forms.Form '''''''''' ' PUBLIC METHODS '''''''''' #Region " Windows Form Designer generated code " Public Sub New() MyBase.New() 'This call is required by the Windows Form Designer. InitializeComponent() 'Add any initialization after the InitializeComponent() call End Sub 'Required by the Windows Form Designer Private components As System.ComponentModel.IContainer 'NOTE: The following procedure is required by the Windows Form Designer 'It can be modified using the Windows Form Designer. 'Do not modify it using the code editor. Friend WithEvents m_OKButton As System.Windows.Forms.Button Friend WithEvents m_cancelButton As System.Windows.Forms.Button Friend WithEvents m_inputlabel As System.Windows.Forms.label Friend WithEvents m_inputTextBox As System.Windows.Forms.TextBox <System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent() Dim resources As System.Resources.ResourceManager = New System.Resources.ResourceManager(GetType(Form1)) Me.m_OKButton = New System.Windows.Forms.Button Me.m_CancelButton = New System.Windows.Forms.Button m_inputlabel = New System.Windows.Forms.label m_inputTextBox = New System.Windows.Forms.TextBox Me.SuspendLayout() ' 'm_OKButton ' Me.m_OKButton.Location = New System.Drawing.Point(122, 105) Me.m_OKButton.Name = "m_OKButton" Me.m_OKButton.TabIndex = 2 Me.m_OKButton.Text = "OK" ' 'm_CancelButton ' Me.m_CancelButton.Location = New System.Drawing.Point(208, 105) Me.m_CancelButton.Name = "m_CancelButton" Me.m_CancelButton.TabIndex = 4 Me.m_CancelButton.Text = "Cancel" ' 'm_inputTextBox ' Me.m_inputTextBox.Location = New System.Drawing.Point(32, 50) Me.m_inputTextBox.Name = "m_inputTextBox" Me.m_inputTextBox.Size = New System.Drawing.Size(250, 60) Me.m_inputTextBox.TabIndex = 1 Me.m_inputTextBox.Text = "file1" '<-------------- The initial filename displayed ' 'm_inputLabel ' Me.m_inputlabel.Location = New System.Drawing.Point(32, 30) Me.m_inputlabel.Name = "m_inputlabel" Me.m_inputlabel.Size = New System.Drawing.Size(120, 16) Me.m_inputlabel.TabIndex = 5 Me.m_inputlabel.Text = inputdesc 'Me.m_inputlabel.font.bold = true ' 'Form1 ' Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13) Me.ClientSize = New System.Drawing.Size(320, 140) Me.Controls.Add(Me.m_OKButton) Me.Controls.Add(Me.m_CancelButton) Me.Controls.Add(Me.m_inputTextBox) Me.Controls.Add(Me.m_inputlabel) Me.Name = "Form1" Me.Text = form_desc Me.ResumeLayout(False) nxopenui.formutilities.setapplicationicon(Me) End Sub #End Region '''''''''' ' PRIVATE METHODS ADDED BY HAND '''''''''' Public Sub m_OKButton_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles m_OKButton.Click 'msgbox(Me.m_inputTextBox.Text) input = Me.m_inputTextBox.text button_result = 0 MyBase.dispose() End Sub Private Sub m_CancelButton_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles m_CancelButton.Click button_result = 2 MyBase.dispose() End Sub Private Sub txt_keypress(ByVal system As System.Object, ByVal e As KeyPressEventArgs) Handles m_inputTextBox.KeyPress If e.KeyChar = Chr(Keys.Enter) Then Call m_OKButton_Click("enter", e) End If End Sub '''''''''' ' PRIVATE DATA '''''''''' End Class End ModuleMark Benson
Aerodynamic Model Designer
To a Designer, the glass was right on CAD.
Thank you for your help. I will try to use the
CODE --> VB
Try partSaveStatus1 = workPart.SaveAs(file1) Catch exc As NXException 'add error catchement here, you can use exc.message to get the reason for faliure End TryThat looks like what I need.
Your post with the windows forms is also very interesting. I am using an inputbox for each variable. I think it is much easier for the used to enter everything in one from. I have not gotten windows forms to work.
I can compile .dll. I am used sharp develop. I have not found good instructions on how to add Windows forms to NXOpen in sharpdevelop (# develop). I will start with your method.
Much Thanks
CODE
Option Strict Off Imports System Imports System.Windows.Forms Imports NXOpen Module Module1 Dim theSession As Session = Session.GetSession() Dim theUISession As UI = UI.GetUI Dim workPart As Part = theSession.Parts.Work Sub Main() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If SaveAs() End Sub Sub SaveAs() theUISession.LockAccess() Dim saveFileDialog1 As New SaveFileDialog() Dim messages(1) As String messages(0) = "This file already exists." messages(1) = "Enter a different name." Dim partSaveStatus1 As PartSaveStatus Dim directoryInfo As System.IO.DirectoryInfo directoryInfo = System.IO.Directory.GetParent(workPart.FullPath) With saveFileDialog1 .Title = "Save As" .InitialDirectory = directoryInfo.FullName .Filter = "Part files (*.prt)|*.prt" .FilterIndex = 1 .RestoreDirectory = True .AddExtension = True .DefaultExt = "prt" .OverwritePrompt = False End With Do If saveFileDialog1.ShowDialog() = DialogResult.OK Then If Not IO.File.Exists(saveFileDialog1.FileName) Then 'save file Try partSaveStatus1 = workPart.SaveAs(saveFileDialog1.FileName) Catch ex As Exception MessageBox.Show("Save-As Error: " & ex.Message) Finally partSaveStatus1.Dispose() End Try Exit Do Else 'ok was pressed, but file already exists theUISession.NXMessageBox.Show("Save As", NXMessageBox.DialogType.Error, messages) End If Else 'cancel was pressed Exit Do End If Loop theUISession.UnlockAccess() End Sub End Modulewww.nxjournaling.com
