New set view
New set view
New set view
I've imported a Pro-E assembly and I've the assembly rotated of 180° different respect the real position.
I've created a new top view.
It's possible to create a new set view that are referred to the new top view ?
Thank you...
Using NX 8 and PDM RuleDesigner
RE: New set view
Yes, right click on model views in the part nav, choose add new view set, and then pick your new custom view as the base view.
I think that should work.
Or move the assembly into the correct position and avoid the trouble?
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
Sorry, tried at the beginning and tried again with your steps, but nothing.
Are you able ?
If yes, can you provide a video made with NX capture video ?
Thank you...
RE: New set view
Sorry just re-checked, you don't need to create or pick a custom view.
- orient the model to your new top view position (I set the WCS and then oriented to WCS to get my position)
- create the new view set in model views
- select TOP from the dropdown, which makes your current orientation into the new TOP
- select which other views you'd like in your new set
- OK it
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
@carlharr, I like that one. Never even knew the view set was there or worked that way.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
RE: New set view
@Anthony, can't remember how I found it, probably missed when I was aiming for something else without my glasses on!
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
Sorry, but doesn't work.
Thank you...
RE: New set view
Ok, I've done what you have wrote a displayed in the video, but nothing.
You are using NX8.5 and me NX8, maybe there is a bug.
Thank you...
RE: New set view
Just checked in NX7.5 and it's worked fine as well. Maybe if you record the same video someone might see where it's going wrong?
Regards, Carl
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
This capability, defining a new 'View Set', has been a part of NX going back to at least NX 5.0.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: New set view
You need to expand the new view set once it's been created, you have selected the original TOP view at the very end of the video.
The new set is "collapsed" until you press +
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
@cubalibre00, I made a new tip video for this, thank you to carlharr for the inspiration.
Anthony Galante
RE: New set view
Glad to have inspired, I should probably retire now while I'm on a high!
www.jcb.com
NX 8.5 with TC 8.3
RE: New set view
Sorry, very stupid...pressing the plus, now I see the new set custom view group.
Thank you again for the patience and support.
Thank you...
RE: New set view
TRIVIA: I'm running NX4 and it (View Set) is even in this version!
