seismic joint
seismic joint
When do I have to have a seismic joint?
I have wood apartment all around the core concrete parking garage, do I have to have the seismic joint between the apartment and garage? Please advise. Thanks.
RE: seismic joint
Mike McCann, PE, SE
RE: seismic joint
RE: seismic joint
Mike McCann, PE, SE
RE: seismic joint
If you are multi-story, you also need to consider vertical movement between 3 floors of shrinking/expanding timber as opposed to static concrete.
RE: seismic joint
Mike McCann, PE, SE
