type of valve package used in HVAC
Dear Friends,
I am new to HVAC. how many type of Valve package use in HVAC Equipment.can somebody explain how it works.
RE: type of valve package used in HVAC
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
But you should compare to your company valve package is. Do you have a company details for the coil you are specifying? Select the manufacturer's package that rersembles it. Or if you want something sepcific and not provided by the manufacturer, then you wont buy the valve package from the manufacturer, and have the mechanical contractor build it in the field
knowledge is power
