SO2 gas and transformer oil analysis
Gents here is one for the chemical boffins. Our plant regularly has SO2 (sulphur dioxide)gas present in the general atmosphere at about 5-15 PPM (occasionally much higher). Question. If this SO2 gas is drawn into an oil filled transformer via the breather in the normal manner in which transformers breathe, could this SO2 gas form any acid (sulphuric) when combined with say 30 PPM of moisture in the oil? The question is really whether the presence of SO2 gas could influence the results of transformer oil analysis?
many thanks
many thanks
RE: SO2 gas and transformer oil analysis
I don't see why not based on previous experience with air-conditioners and air compressors. Any where there is Carbon, Hydrogen, Sulphur and water it wil eventually make an acid. I have seen air compressors fail due to acid and the coils of large airconditioning units collapse from acids. Low concerntrations of sulphides can also cause sulphide stress cracking in stainless steel. I will sned an e-mail to a friend. If he response, I will post it here.
