FEA ANALYSIS IN COMPRESS SOFTWARE
In Compress, during the analysis of FEA for Self reinforced nozzle, the result FEA model shows as if nozzle is not attached to the shell, there is a huge gap between nozzle and shell. This raises the doubt whether compress actually check the nozzle to shell weld junction for Self reinforced nozzle.
Anyone kindly clarify!!!
thanks
Ananth
thanks
Ananth
RE: FEA ANALYSIS IN COMPRESS SOFTWARE
If you open up the options menu for the FEA analysis, you can choose to force this area to be analysed. (I haven't tried this as for fatigue analysis I have used other methods...).
Cheers,
Marty
Thanks for your help
Cheers,
Ananth
