Assembly Cut or Promote Body?
I have a small sub-assembly with only 8 parts. The parts have no holes at the part level. This sub-assembly (assy-1) will be used in the next, upper, sub-assembly (assy-2) where each part will have 1 to 2 holes applied. That sub-assembly (assy-2) will be used in the next upper assembly (assy-3) where other parts will be added and located in the holes that were cut in the previous sub-assembly (assy-2). That assembly (assy-3) will then be used in another assembly (assy-4) and that will be used in the next 3 assemblies (assy-5, 6, 7). So you can see that (assy-1) is the foundation for the final, large assembly.
My question is kind of a poll, what is better for cutting the 12 holes in assy-2, a promote body or assembly cuts and why?
RE: Assembly Cut or Promote Body?
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I always thought that was the case John but it seems sometimes that the more complex the assembly cuts are the more unstable it becomes in the upper assemblies. That is one reason I am asking this question, to see if anybody else has seen some problems with either assembly cuts or promotions.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
