CLAMP DESIGN IN NX8
CLAMP DESIGN IN NX8
I'd like to create a connection design between Revolve (0) and Extrude (3), using their faces (in yellow) or their edges.
I got the Through Curve Mesh (23) just to show how I’d like the shape of the connection to look like.
How would create this?
MZ7DYJ
RE: CLAMP DESIGN IN NX8
1. move face: i have moved the face of the left flat body to the start of your bridge curve(20)
2. I have created bridge curves on the other side of the body, too.
3. I have creted 4 'through curve mesh' sheet bodies.
4. I have used 'extract geometry' command with Geometry Type set to Face. I have selected the faces, that you have painted yellow.
5. now, i have sewed all 6 faces into one solid body.
6. with unite command, I have combined all three solid bodies into one.
If I manage to create smaller movie, I will upload it.
I hope it will help.
MZ7DYJ
Can you send as a parasolid, please?
MZ7DYJ
MZ7DYJ
You had the right idea, you just needed to add more wireframe (Brige Curves) and build some for support of the "blend" surface, which can be made by creating lines tangent to the blend edges of the Revolved surface and then projecting them down on the the Extruded platform.
Static wireframe display shows the surfaces are all tangent (changed Smooth Edges to Phantom) or close enough, given your Modeling tolerances.
CLAMP_nx8.prt
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Thanks a lot!
MZ7DYJ
