Loading ResultMath Template in Hyperview
Note the following:
1) I carried out a frequency response Analysis SOL 111 and got the results in ".op2" format.
2) I tried to implement tutorial HMath-5000 so i defined a function in Hypermath and saved it as ".hml".
3) To register the above function i wrote a script in a simple "post_rmath.mvw" file. (given at the end of this post)
4) I registered post_rmath.mvw and loaded it in hyperview. Then i applied the same function "" to my structure model.
5) When i generate contour for the above function i get the following error:
"This ResultMath Template is designed to be used for advanced use-cases and for full functionality requires a certain set of datatypes which are note available in provided files"
Can anyone help me in this regard? I have not registered any result template in post_rmath.mvw file. As far as i think this error is due to the usage of wrong result template.
SCRIPT FOR STEP 3- post_rmath.mvw is given below:
*Id("HyperStudy v12.0")
*BeginDefaults()
{rmath_template_dir = getenv("ALTAIR_HOME") + "/io/result_readers/rmxml"}
*BeginGraphicDefaults()
*RegisterResultMathPlugin(Brittle_Calcs, "Brittle failure theory", HYPERMATH, "<your_location>/HyperMath_Brittle.hml", SCALAR, ELEM, "", "Hml_BrittleMatFailureTheory", "")
*RegisterResultMathTemplate("Standard", {rmath_template_dir + "/standard.xml"})
*RegisterResultMathTemplate("Advanced", {rmath_template_dir + "/advanced.xml"})
*RegisterResultMathTemplate("NVH", {rmath_template_dir + "/nvh.xml"})
*RegisterResultMathTemplate("Composite", {rmath_template_dir + "/composite.xml"})
*DefaultResultMathTemplate("Standard")
*ResultMathState("On")
*EndGraphicDefaults()
*EndDefaults()
RE: Loading ResultMath Template in Hyperview
I altered the above script to the following:
*BeginDefaults()
*EndDefaults()
