GRE pipe
GRE pipe
Where can I get GRE pipe weight? I am also looking for support spacing data for GRE pipes.
RE: GRE pipe
http://www.futurepipe.com/en/Fiberglassbook.pdf
RE: GRE pipe
RE: GRE pipe
RE: GRE pipe
RE: GRE pipe
The thickness varies depend on your Pressure & temperature.
Hence the Pipe weight changes accordingly.
It might be GRE, GRP, GRV etc, only the resin typ will change for the
Pipe manufacturing. Also, there is two types of Pipe manufacturing.
1. Continous type
2. Dis-continous type (mandrel type).
Best of luck
RE: GRE pipe
epoxyresin = 1,1 g/cm3.
glass = 2,5 g/cm3.
