Looking for Sticky Gel
Here is something i need help in finding.
Its a Sticky Gel that is flexible and elastic slightly firm that is used to hold things in place.
Specifically iam looking for the stuff that Gel-Pak uses in there Sticky boxes:
http://www.gelpak.com/gel-box-ad/
I know there Gel is proprietary. But there is several companies and several product all over the world that use this kind of Gel. Like Sticky Pads or you know those kits toys slap and stick which is too soft for what i need but its similar.
It might not be the exact same but close enough is ok with me.
I have some Boxes/cases that i need to add this for my optics so they dont move around.
From what i can tell its a polymer. But maybe silicone Gel might work to.?
Ive hit a wall as there is limited info on what ive been at least searching for.
If a video is needed to get a closer look at this stuff i can make a video as i have a couple cases here from Gel-Pak.
My plain it to fill up these:
http://www.ebay.com/itm/ESD-safe-SMD-IC-Organizer-...
SO when i put all the separate little optics in they wont move around and get damaged.
I have alot of little optics so to buy 100+ Gel-Pak cases is not what i want to do.
Any help would be gratefully appreciated on this.
RE: Looking for Sticky Gel
Tom Quinn
Adherent Laboratories
www.adherentlabs.com
