Seeking architect/designer for chemical plant
We are is actively seeking consultants/architects/plant designers for the design of a chemical plant in Tucson, AZ.  Does anyone know how/where we can find this expertise?
The contracted company should preferably be located in Southern Arizona. Thank you!
RE: Seeking architect/designer for chemical plant
What type of plant do you want to build?
Your State Professional Engineering Board or Association will be able to help .. you likely need to start with chemical project engineers, professional engineers licenced in your State to approve designs.
Best wishes.
Marydiff, Have you checked into the likes of Bechtel, Fluor, Brown & Root, JR Brown, Davey, Sargent & Lundy, just too name a few? They can set up a turn key project for you.
Goodluck!
saxon
