units in formulas
units in formulas
in pipeline construction I am used to deal with loads per unit length, i.e. lbs/ln ft
I spell : pounds per linear foot
In a USA book I found : pounds per lineal foot
In dictionary I can find only : linear.
Is it a typing mistake or is equivalent ?
RE: units in formulas
http://dictionary.reference.com/browse/lineal?s=t
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The third meaning given is as a synonym for "linear".
I would definitely use "linear metre / foot" rather than "lineal meter / foot" for the OP's example of load or weight per unit length.
http://julianh72.blogspot.com
"Lineal" is in the Oxford dictionary my mom used to play Scrabble. That makes it correct. :)
I was told by one of my teachers in college not to put the "s" after "lb". "lb" is Latin.
Why can't you call it lb/ft. Is there some other use of linear units that require you to note that they are linear?
JHG
I put my example down to la-di-da fashion marketers elevating their decorative wares over the mundane timber and metal industry with an inflective "al" on the end of "linear". But that doesn't explain its use in your USA book!
Reminds me of the joke "This is sure a wide runway!" "But look how wide it is"
As to "linear" vs. "lineal" people really do want their work to seem important. Somehow many think that using terminology that is not in broad usage makes it look more important. It doesn't, but people want it to. When I see "lineal" I think "linear" and go on about my life leaving them to their little triumph. If I have to reply in writing to someone who insists on "lineal", I respond with "linear" because I cannot bring myself to participate in their pomposity. If they have the temerity to correct me on that point I just ignore them.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
Spanish is a strange one - when I was working on underwater cable systems, we had to identify lasers as male (el ...) and receivers as female (la ...). Never thought about it until I accidentally type la for a laser and was told "you can't do that - lasers are male! It has to be el". Guess it is the same in all the Latin based languages.
[/off topic]
--Winston S. Churchill
The Awful German Language, by Mark Twain. Read the Tale of the Fishwife and its Sad Fate.
JHG
I once worked with a man from Argintina who said he went to buy a piece of lumber. He asked for "a two by four 8 feet long." Get this guy a 2x4 8 foot long. Next time he asked for "a 2x4 8 foot long." Oh -- you want an 8 footer. Now he was really confused and did not know for next time if he should feet foot or footer.
Design for RELIABILITY, manufacturability, and maintainability
I put my shirt in the wash and it shrinked
Err no, it shrank ...
Hmmm.. it shrunk ...
I've gone fatter since it was washed
