Journal - add object to array
I have problem with journal:
I use SelectsObject for create first group/array of Lines p.ex. FirstGroup As NXObject.
After for each element in FirstGroup I create new line (p.ex perpendicular in intersectionpoint with face).
And I want add every line to second group/array (SecondGroup As NX Object).
If I must add this element by select on screen - it's no problem.
But when I must add new element to existing array - I don't know what I must doing.
I think it's easy, but I don't know...
Mayby somebody can help me?
Best regards
Michał Nowak
Best regards
Michał Nowak
RE: Journal - add object to array
thread561-366364: "NXOpen.NXException.Invalid file name" error message
Here's some example code that works with point objects; create a new file and add a few points. Run the journal and select at least 1 point object.
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Imports NXOpen.UI Module Module13 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUi As UI = UI.GetUI Dim workPart As Part = theSession.Parts.Work Dim rnd1 As New Random() Dim max As Integer Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim myPoints As New List(Of Point) If SelectPoints("Select points", myPoints) = Selection.Response.Cancel Then Return End If MsgBox("number of points selected: " & myPoints.Count.ToString & ControlChars.NewLine & _ "That's not enough, let's add 100 more") If workPart.PartUnits = Part.Units.Inches Then max = 10 Else 'metric file max = 250 End If 'create Point3d using the constructor Dim myPt1 As New Point3d(0, 0, 0) For i As Integer = 0 To 99 'change values of myPt1 using random numbers myPt1.X = rnd1.Next(-max, max) + rnd1.NextDouble myPt1.Y = rnd1.Next(-max, max) + rnd1.NextDouble myPt1.Z = rnd1.Next(-max, max) + rnd1.NextDouble Dim newPt As Point newPt = workPart.Points.CreatePoint(myPt1) newPt.SetVisibility(SmartObject.VisibilityOption.Visible) myPoints.Add(newPt) Next For Each tempPt As Point In myPoints tempPt.Highlight() Next workPart.Views.WorkView.UpdateDisplay() MsgBox("The list, 'myPoints', now contains: " & myPoints.Count.ToString & " points") For Each tempPt As Point In myPoints tempPt.Unhighlight() Next 'if you need the point objects in an array (some NXOpen API functions only accept an array), 'use myPoints.ToArray - this will return an array of the objects that are in the list End Sub Function SelectPoints(ByVal prompt As String, ByRef thePoints As List(Of Point)) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select points" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(0) As Selection.MaskTriple Dim selObj() As TaggedObject With selectionMask_array(0) .Type = NXOpen.UF.UFConstants.UF_point_type .Subtype = NXOpen.UF.UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selObj) If resp = Selection.Response.Ok Then For Each tempObj As Point In selObj thePoints.Add(tempObj) Next Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function End Modulewww.nxjournaling.com
