Advanced Powercopy
Advanced Powercopy
Hi everyone,
I am currently working on a powercopy that will instantiate simple part bodies.
I want to be able to have the user input a number of instances and the powercopy will create that number of instances entered.
Has anyone been able to perform this type of action.
My workbenches are limited to only KWA and KWE, so using PKT with User Defined Features is not an option.
Zelym
Zelym
RE: Advanced Powercopy
Look at Knowledge Template, it might be what you looking for, but you might need some extra licenses...
I think I am now going to have a script that will instantiate the powercopy by searching for axis systems and using these as the input.
What type of prompt or code do I need to instantiate to searched elements within a script?
Since I am new to coding I would normally record the action inside CATIA but it does not record anything with instantiating a powercopy.
Zelym
There is a CATScript that is in the install path that can be used as an example. Unfortunately you would need a KT1 runtime license which you might have as it is bundled in some packages.
C:\Program Files\Dassault Systemes\B23\win_b64\VBScript\PowerCopy
Win XP64
21SP7/22SP5, 3DVIA Composer 2013X, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
