hole callout dimension value
I have the following hole in a plate.
Ø.375 3/4"DP
SolidWorks will only let me have decimal place or fractional dimensions not both.
How do I get it displayed like I shown above dia at .375 depth at 3/4"
Certified SolidWorks Associate
SW2009 X64 SP4.1
Dell Precision T3600
Nvidia Quadro 4000
Xeon 3.2GHz Quad Core, 8GB RAM
Win 7 Pro X64
RE: hole callout dimension value
If you used the Hole Wizard to place the hole, you can click on the dimension in the drawing and change the Callout Value to Depth and then go to the Other Tab and check Override Units, change to fractions and make your denominator 4.
Sylvia
Perfect thanks.
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
