Disposal of Demineralized Water
Does anyone have any experience with draining demineralized water to the ground? We are trying to dispose of demineralized water which would NOT be released into any "waters of the state," however, the state environmental department is dragging their feet on giving us concurrence. Can anyone prove that their is no environmental risk or does anyone currently dispose of demin water by draining it to the ground?
RE: Disposal of Demineralized Water
Good luck!
If you must dispose of it, why not mix it with another stream ... like raw water if you must and re-use it in your plant, or, blend it with a waste stream ... your waste stream quality will surely improve.
Lack of minerals (demineralized water) aint much different than distilled water, or rainwater. Shame to waste good demin water though... can't see why you need to make it and waste it?
good luck.
V
Edwin Muller
KEMA Power Generation & Sustainables
Arnhem, The Netherlands
E-mail e.f.muller@kema.nl
Internet: http://www.kema-water.nl
