Employing 9-node quadratic lagrange element in Mindlin plate
By employing 9-node quadratic lagrangian rectangular elements in finite element analysis of Mindlin plate (FSDT) instead of
linear ones in my code, a discontinuity in deflection at the middle node of each element is observed as it can be seen from
the attached figure. While by using 8-node serendipity rectangular element, this even doesn't occur. Any help would be much
appreciated. Regards.
RE: Employing 9-node quadratic lagrange element in Mindlin plate
