Composite conduit
Composite conduit
Composite conduit
I'm sending this e-mail to request information on availability of composite conduit with the following properties;
inside diameter 0.125" to 0.250"
Wall thickness 0.020" to 0.032"
Length >10ft
Highly flexible
Good heat transfer properties
Operating temperature -50F to 300F
Any color
High impact and tensile strength
Suitable for under water operation
RE: Composite conduit
Hello Bman:
We are in the process of working with a company that has a new resin that we are testing now to use to make composite conduit out of. I know it has the strength and temp. will not be a problem. If you are wanting this for salt water it will be perfect this stuff is anticorrosive. The flexibility is one I'm not sure of. I will have to check with the Chemist. If you are interested get back in touch with me. How much conduit do you need? Look forward to hearing from you.
Gregg
