Soccer Ball Modelling
4
Hi
Could anyone please suggest the correct procedure to create 3d model of soccer ball with 12 pentagon and 20 hexagon in nx7.5?
Ras Bihari
RE: Soccer Ball Modelling
Have a look here for the formula http://en.wikipedia.org/wiki/Truncated_icosahedron#
Once you have the side lengths i cant see it being more than just extrudes, patterned and intersected with a sphere.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
Still I am not able to create the ball, Once I assumed the side length of regular pentagon then how would we get the angle b/w normals of two adjacent polygon and the radius of sphere?
Ras Bihari
I got it.
Ras Bihari
Soccer is my favorite sport, but I've never designed a soccer ball......
Nice thread!
Anybody involved in soccer as a player or/and coaching?
MZ7DYJ
Attached is a zip file containing my solution for creating a so-called standard soccer ball. Included are a series of images which shows the steps that I took to create the model. The only really important file is the one named 'soccer_ball_solid.prt' as it's a parametric model in the sense that there is an expression named 'Diameter' which is set to 220 mm, which I understand is the size of an official competition soccer ball. But if you needed something smaller (or larger) all you need to do is enter a different value.
Here is what it looks like:
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If you go back and look at the sequence of images in my ZIP file showing the approach that I used, you'll see when looking at 'Step 6' and 'Step 7' that that is basically how I did this as well:
Step 6
Step 7
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Great work guys!!! Just awesome!
