ôSpecificö point constructor
Hello community,
I am wondering if it is possible to simply [and only] start any construction feature in NX with a simple “launch” command. This means that only the start window of the construction feature is shown. Especially, I am interested in the creation of a point therefore the example provided above will deal with the point constructor.
The code should look something like that.
As you can see the aim is to simply start a desired feature. Finally the user will click on a button inside a windows form (VB application which is executed in NX) and the standard point constructor window will appear. The only difference in comparison to manually start the point constructor is the fact that a few options are preconfigured. It is very important to somehow implement an additional line of code in order to do further stuff with exactly this point.
In the past the following strategy worked pretty well (also with a lot of other NX features).
It is possible to access the point via the “Desired_Point” variable for further manipulations. You cannot just click the “Record Journal” button then click on Insert -> Datum/Point -> Point… then set the desired configurations and stop the Journal Recording in order to build a “specific point constructor launcher”.
Needs for the specific point constructor window:
Language: VB
Feature: Insert -> Datum/Point -> Point…
Default configuration:
- Type: Inferred Point
- Settings: Associative [Box is checked]
Filters:
- Type filter: { } [no entry is chosen by default]
- Selection Scope: Entire Assembly
Anyway is this possible in general?
Best regards,
Polynom3000
CODE --> Pseudo
<Launch> Insert -> Datum/Point -> Point… ‘desired feature Default_config1 = … Default_config2 = … </Launch>
CODE --> VB
Dim Desired_Point As String … Dim nXObject1 As NXObject = CType(nXObject1, NXObject) nXObject1 = pointFeatureBuilder1.Commit() Desired_Point = nXObject1.JournalIdentifier
Language: VB
Filters:
Best regards,
Polynom3000
RE: ôSpecificö point constructor
If you do not have such a license, there are a few functions that will show dialog boxes for the user to interact with. Among these are:
- PointConstruct
- SpecifyScreenPosition
- SpecifyVector
- SpecifyPlane
- SpecifyCsys
Unfortunately, there is no generic 'command launcher'.www.nxjournaling.com
Best regards,
Polynom3000
