catia macro for auto fixing of parts going through the tree.
hi there first post here.
i have years of catia under me but not in scripting
i need to make a macro as per the titler but i cant seem to get it to be selectable such that it works on any part not the one it was recorded with.
i need it to work down the tree fixing inside sub branches as it goes and then hiding the fix anchors
please help!!
please help!!
RE: catia macro for auto fixing of parts going through the tree.
This is a really fun question...of course I say that because I made this up a few years ago
The trick in this is to begin to understand how a recursive function works.
The following is a code to run in catvba. I won't say it's great, or well commented, or has great error handling, but I think it works pretty well. There's parts of it, particularly how the recursion call works, that I've been able to reuse in other applications.
Hope that helps.
Mark
CODE --> CATVBA
'*************************************************************** 'Macro to Delete existing constraints, and create FixInSpace constraints 'Operates recursively on all levels within the current document 'By Mark Forbes 'Original Version 0.1.0 May 19 2010 'Version 0.1.1 June 8 2010 Handles deactivated components 'Version 0.1.2 Sept 16 2010 Handles CATProducts only once, better error handling ' on deactivated products, and prompts to skip Flexible Subassemblies 'Version 0.1.3 Feb 1 2011 Hide constraints, Late Bind oCurrentProd for R19 'Version 0.1.4 March 10 2011 : Adding more error handling '*************************************************************** Public oList As Variant Public oSelection As Selection Public oVisProp As VisPropertySet Option Explicit Sub CATMain() 'Declarations Dim oTopDoc As Document Dim oTopProd As ProductDocument Dim oCurrentProd As Object 'Dim oVisProp As VisPropertySet 'Check if the active document is an assembly, else exit Set oTopDoc = CATIA.ActiveDocument If Right(oTopDoc.Name, 7) <> "Product" Then MsgBox "Active document should be a product" Exit Sub End If Set oSelection = oTopDoc.Selection Set oVisProp = oSelection.VisProperties Set oCurrentProd = oTopDoc.Product Set oList = CreateObject("Scripting.dictionary") 'CATIA.StatusBar = "Working On" & " " & oCurrentProd.Name Call FixSingleLevel(oCurrentProd) 'Call the subroutine, it is a recursive loop CATIA.StatusBar = "Macro Done" MsgBox "Fixing Macro Finished" End Sub Private Sub FixSingleLevel(ByRef oCurrentProd As Object) On Error GoTo Err_Handling 'More declarations Dim ItemToFix As Product Dim iProdCount As Integer Dim i As Integer Dim j As Integer Dim oConstraints As Constraints Dim oReference As Reference Dim sItemName As String Dim constraint1 As Constraint Dim pActivation As Parameter Dim n, m As Integer Dim sActivationName As String Err.Clear CATIA.StatusBar = "Working On" & " " & oCurrentProd.Name Set oCurrentProd = oCurrentProd.ReferenceProduct iProdCount = oCurrentProd.Products.Count Set oConstraints = oCurrentProd.Connections("CATIAConstraints") n = oConstraints.Count 'Remove Existing Constraints m = n For i = 1 To m oConstraints.Remove (n) n = n - 1 Next For i = 1 To iProdCount 'Cycle through the assembly's children Set ItemToFix = oCurrentProd.Products.Item(i) CreateReference: sItemName = ItemToFix.Name CATIA.StatusBar = "Working On " & oCurrentProd.Name & " / " & sItemName Set oReference = oCurrentProd.CreateReferenceFromName(sItemName & "/!" & "/") Set constraint1 = oConstraints.AddMonoEltCst(catCstTypeReference, oReference) constraint1.ReferenceType = catCstRefTypeFixInSpace oSelection.Add constraint1 'Set visibility to hidden oVisProp.SetShow catVisPropertyNoShowAttr oSelection.Clear RecursionCall: If ItemToFix.Products.Count <> 0 Then 'Recursive Call If oList.exists(ItemToFix.PartNumber) Then GoTo Finish If ItemToFix.PartNumber = ItemToFix.ReferenceProduct.Parent.Product.PartNumber Then oList.Add ItemToFix.PartNumber, 1 Call FixSingleLevel(ItemToFix) End If Finish: Next GoTo End1: '*****Error Handling Err_Handling: sActivationName = oCurrentProd.Name + "\" + ItemToFix.Name + "\Component Activation State" 'Build the reference Name Set pActivation = ItemToFix.Parameters.GetItem(sActivationName) If pActivation.ValueAsString = "false" Then CATIA.StatusBar = "Error, Try To Activate " & ItemToFix.Name 'Tell the user what is happening pActivation.ValuateFromString ("true") ElseIf pActivation.ValueAsString = "true" Then 'Assume this is a flexibe component j = MsgBox("Error on " & oCurrentProd.Name + "\" & ItemToFix.Name & vbCrLf _ & "This element may be a flexible component, have an invalid" & vbCrLf _ & "Instance Name, or other error" & vbCrLf _ & vbCrLf _ & "Skip component and continue?", vbOKCancel, "Error") Err.Clear If j = 1 Then Resume RecursionCall If j = 2 Then CATIA.StatusBar = "Fix All Aborted" End End If Else: Resume RecursionCall End If '*****End of Error Handling End2: Resume End1: End SubRE: catia macro for auto fixing of parts going through the tree.
ill try this when i get an assembily that needs it tehn forward it through for some formal testing witha few tweeks for what i need aditionaly doing. such as hiding all teh constraints once correct.
how would i do this? recursive hide of constraints??
It's not VB Script, it's CATVBA, which means you'll need to copy all that into a module in a catvba file. If you search the forum and google, there's lots of resources about how to use that.
Mark
i have had time to and noticed that it does hide, i still woudl hve to go through and hide the constraints node but thats not an issue.
is there any method to stop it from going through anything more than what is blue boxed?
I have tried today as i was given time to work on this and it keeps runign into a out of memory error or a script entry point error, this was not happening the other day when i tried have you any ideas what i am doing wrong.
i closed everything on the desk other than catia and tried again and still no look. vb help says its somthign to do with 64bit memory block runing out and it stops at the first stage. this is a small assembily only 126 parts.
regards Phiill
thankyou for your help.
