Pattern in NX8.5
Pattern in NX8.5
Pattern in NX8.5
Is there any way to import data for angular pitch values from external spreadsheet to make circular pattern. I tried with "use spreadsheet" option but couldn't able to import data.
RE: Pattern in NX8.5
Maybe the reuselibrary provides you a work around.
When you have the Spreadsheet 'interface' open, you can 'Copy & Paste' data from other spreadsheets into this 'spreadsheet'.
Now if you want an actual link to an external spreadsheet, your best bet is to go into the Expression system and using the 'Spreadsheet' f(x) functions, create expressions which are linked to cells in those external spreadsheets and then use these expressions when creating your Patterns in NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
