ASME Section I, IV or VIII Software recommendations?
There are several commercial products relating to ASME Section VIII, division 2 software (CodeCalc, Compress, etc.). Could anyone recommend any of them? I'm interested in code calculations as well as design optimization software for asme sections I, IV and VIII.
Thank you for any recommendations and/ or links.
RE: ASME Section I, IV or VIII Software recommendations?
Dear rich99 (Mechanical)
See MECHANICAL ENGINEERING: vol.124/no.10 OCT. 2002, page 61,62,63,64
1.    CODEWARE www.codeware.com ASME Pressure Vessels: COMPRESS/ASME-TEMA EXCHANGER/TUBE SHEET/XML Technology to PDMS & PDS/DRAFTER/COSTERR/FE-PIPE, NOZZLE PRO, AIX PRO, BOS FLUIDS
2.    COAED    www.coade.com
3.    DISASU    www.disasuengr.com
Leonard
where i can fin a small excel  clac. sheet for preliminary ASME calc
Take a look at www.cerebroinc.com. Program to calculate pressure vessels under ASME section VIII - Div 1.
mixsist
Compress by Codeware is the best, though not cheap. Computer Engineering's APV is second. There is no third. One man's opinion, have used both of above.
Dear PVinspector (Industrial)
I agree that COMPRESS by Codeware is the best for ASME Pressure Vessels Section VIII Div 1, Div 2, ASME HEAT EXCHANGER, TEMA HEAT EXCHANGER, FLANGE DESIGN for the
Mechanical Analysis:
API 579 Level I & Level II APP. "A".
API 597 Level III FE-NOZZLE APP. "B"
Also, Mehanical Analysis:
API 579 Level III: APP. "B" : FE-PIPE, NOZZLE PRO, AIX PRO (FLANGE DESIGN & ANALYSIS), BOS FLUIDS.
Additional Compress now give you your drawing in the following format: AUTO-CAD 14, 2000, 2002; PDS INTERGRAPH; PDMS CADCENTER.
Compress Reports is the best.
I am Certificate: PV-LITE, DISASU, COMPUTERENG. PV-VESSEL,
(COMPRESS/FE-PIPE, NOZZLE PRO, AIX PRO, BOS FLUIDS).
www.thill.biz
Normally All softwares are good at one point of time where in I have the software called Microprotol - wherein it can handle PV,HE , COlumns and AIrcoolers - Mechanical design as per ASME SEC VIII DIV 1 and it has good interface with Autocad, Microstation , PDS and Now with HTRI too .
You can contact me for more information on this
prabhu74@yahoo.com
HI AP (Mechanical)
Thank you for the additional informationa on an additional PV SOFTWARE PACKAGE: "Microprotol".
Leonard@thill.thill
www.thill.biz
