Demonstrate symmetry in structural drawing
RE: Demonstrate symmetry in structural drawing
I have never seen it before in mechanical design side.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
14.5-2009 Fig 1-35
If that figure is the same as 1-33 in ASME Y14.5M-1994 then it's not the same case as the sketch the OP posted. Section 1.8.8 and figure 1-33 in ASME Y14.5M-1994 is about only dimensioning one side of a symmetrical part, dimensioning it from the center line. The OP is dimensioning across the center line.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
